I continued on the right wing assembly by match drilling the upper wing skins to the skeleton. Afterwards I attached the lower wing skins to the wing skeleton and match drilled those also, see image 1. Then I placed the right wing leading edge on the spar and clecoed it on. The leading edge inboard rib along with the leading edge joint plate were positioned and match drilled in place, see image 2.
